Automation De-coded: Using JMP’s Workflow Builder
Workshop
Discover how to work smarter with JMP Workflow Builder! This powerful tool makes it easy to capture your steps as you work, without writing any code. Just start recording, do your work, and save the workflow to reuse anytime or to share with colleagues. In this hands-on session, learn how to get started with Workflow Builder to automate routine tasks and streamline your analysis process. We also explore how you can customize your workflows to make them more flexible and interactive using built-in features that generate code for you. Whether you're brand new to Workflow Builder or curious about what else it can do, this workshop shows you how to get the most out of this tool. A basic familiarity with the JMP Scripting Language (JSL) is helpful but not required.
This workshop takes place outside of the main Discovery Summit conference. It is not included with your registration fee.
Info
Fee: $
100-200
Presenter
